Go from connecting 2 receivers to 3 | SatelliteGuys.US
Buzzdar
735
USA
how do i go from connecting 2 receivers on a dish 500 to connecting 3 receivers i have had the same set up for the past year
Most likely you will have a Dish Pro Twin if it is a year old, you would need a DP34 switch to expand it to 4 receivers. But as webbydude said it helps to have as much information as possible to give a correct answer.
What he prolly needs is a quad for add'l receivers.
But he could save money by getting a Dish Pro Plus lnb and upgrade to a twin tuner.
fred
Pathetic 811 receiver #3
Photos Albums on the 622
