going from top 120 to top 180 annual sub | SatelliteGuys.US
rcwilcox
300
2
I noticed on the adding VOOM HD channels that thodse who had an annual subscription had to be converted to monthly before they could change their programming. I have top 120 and just paid the annual on the 120 if I go up to the top 180 what happens to my annual? I don't want to be converted as it is a 30 some dollar savings annually. Anybody have this experience?
Yes. Basically they would end up crediting you for the remainder months that you did not use and then charge you for the AT180 if I am not mistaken. I am not sure if you would end up getting penalized for one month as a result since you did not take the whole year with AT120 or not. They may also just charge you the difference of what remains for the year between the two packages which is most likely what they would do.
Stupid Technical Question.
Another of the many questions about the new HD channels
