Good c band lnb | SatelliteGuys.US
Good c band lnb
Are you looking for a LNB or a LNBF? (LNBF has an attached Feedhorn and an LNB bolts to a feedhorn).
C-band or KU-band? C-band LNBs and LNBFs are not usually dual band (high/low) and are typically standard single band with a single LO frequency and no switching.
A hobbyist favorite and proven performer C-band LNBF is the GEOSATpro C2.
If you are looking for a LNB, I will let someone better informed assist.
The best lnb's for c-band is the line of Norsats..no question about it..I'm sure the majority on this forum will agree..
sadoun used to have them, but i just bought as many as i could afford... :P
I am going to find out how they work with the openbox.
Should get a Cband - Ku Combo the has both lnb on one unit that way you can have the best of both worlds. on KU I would go universal khz 10600. you can buy here I believe from WSI or you can but DMS but you should review any products before buying so you can purchase one that you will like.
Mind teaser or too much spare time.......
Good satellite receiver for c band
