Got 10 ft up and pics | SatelliteGuys.US
xxtornxx
95
usa
Got dish up this week and tryed the toshiba trx 80 to move and it moved about 1/4 in thats it.The unit blinks off when you hit west or east move sat and you here a clicking sound like its shorting out and comes back on. Must be doing some thing wrong with set up not famillar with this unit.Like to get this unit to move dish to save money for the new unit.I got a battery charger to move and moves east-west no problem .http://www.satelliteguys.us/c-band-satellite-discussion/171953-found-10-ft-dish-will-need-help.html This link will show lnb if i need new one or can i at least set up unit.Trying to find southern sat with no degrees scale on motor i will be looking in the blind.Ajak h-h motor.
It looks so lonely out there. Nice looking install. I would check your sensor wires for the motor and make sure they are hooked up good. Also might be the sensor itself.
Is it safe to say you may not like your neighbors or are you installing it in a prison courtyard? Other than that looking nice.
I took a 6v charger out and hooked it to the motor and it moved east to west and i think the receiver toshiba trx-80 is shorting out.When i hit move the receiver shuts down. If i had to go with an other way to move to ajak motor would a vbox work or any other ideas.Oh i live in an HOA and my wife siad some one was driving around lokking hard iam sure it not a B.U.D. head like my self admiring the cool dish no I dont think so. My wife said wait a little while and see what happens befor investing.
Thanks to all for the help and taking a look at pics.
Yes north of suprise AZ on the 60 west of 303 That is the white tank mts. out my front door. Got sick of neighbors and traffic, if i want to go shooting I 4 wheel it down at the end of the street and start blasting or dirt bikeing.I deliver in mesa for Alby food stores and that 60 is getting bad and the growth of the city was boomming.
I've drove the 303 a few times on our way to Bullhead city. It's alot better than taking Grand Ave. :eek::D.
Here an old pic from 2006 when i had both the 6ft and 10ft up.
If I recall correctly, this issue is fairly common and is caused by a bad capacitor on the front panel of the TRX-80. I don't remember the cap label. I did this repair a few times but it has been years. It's not that hard but you have to remove the front panel.
And how often do you go to Bullhead City? I live in Golden Valley and work in Oatman.
Photto
At least once a year. My wife has family there. I'm familar with Golden Valley too, as my wife's grandmother lived their. 1 bro'n'law works at Findlay motors and the other works at the casino in Laughlin. My father'n'law used to live their too. But he recently moved to Nashville.
OK I Googled and found it - the caps are C809 and C810 on the front power supply. One is a 10uf and the other is a 33 uf electrolytic capacitor. Remove the front panel and you can unsolder both without removing the power supply. Their identifiers are etched on the back of the power supply. Use a pair of tweezers to remove. Pay attention to polarity in replacing caps. One has the negative to the left (as you look at it). The other has the negative to the top.
This is an issue with the TRX80, TRX100 and TRX120.
OK Lynskyn i'll try and take a look at what you telling me. Is it a better get a gbox at sadoun for 79.99 and elimenate this old recevier?
The W-x satellites and mapping them in
NPS Flyer
