Got Splitter Questions, Again (LOL). Your Help Would be REALLY! Appreciated. | SatelliteGuys.US
Tele-TV
106
Soooo..... this is what I want to do [just came back from Radio Shack {RS}]. They didn't have what I needed (5? way splitter).
I have 2 lines running off my D* dish both going into my Sony D* DVR. What I want to do is take the SIGNAL from the exisitng 2 lines and split the signal (both of them) to my HD Tivo. So I don't have run anymore lines from my dish right now $ [drill more holes in my wall].
The guy at RS told me I need a 5? way splitter, is this correct?
I'm DYING! to know. :) Thanks.
nope...need a multiswitch to do that...Splitters wont work
I assume you have the original dish (not a Phase III)
Hi Iceberg. :) I have the 18x24/eliptical/oval/3 LNB dish. I don't know how I left out so pertinent info (sorry and thanks).
1. What would I need to do from here?
2. I have a feeling it will be cheaper to get one from RS (if they have them), instead of my Sat [local] installer guy. Is there a good, RELIABLE brand I should ask for (not just at RS, but other places.
Thanks.
you can't split the lines once it comes in the house. You would have to run 2 more lines
What a multiswitch does is allows you to run 4,8,16 receivers off one dish. The Phase III has 4 outputs. This multiswitch gets hooked on all 4 of those and allows you to hook up more receivers.
You will need 2 more lines from the dish to the new DVR (Tivo)
Here is what you need for a multiswitch (if you went that route)
Thanks. That's not what I wanted to hear. :( Will have to wait. Figure something out/go to plan B.
Matthew
d10 features (lack of)
Newbie Help with DVR
