Got the dish up. Wiring Help | SatelliteGuys.US
i4tas
791
4
Northern USA
Panasonic
VideoClipher II Plus Descrambler
Videopal Order recorder
Integraded Satellite receiver
PS-500SU
FB2610071
This is what the back of the box looks like. Gray Black Red Blue are the colors for the wire feeds.
Antenna
Actuator
V/H 50mA
SW + DC5v
G B R B
G B R B
+ GND DC5v Pulse
0.5A
PLOAR
Then this is the other wire port
Use Class 2 Wiring ONly
X X X
ground
Out Put
Dc 24V
4A MAX
FOR 5 Min
Wires
from accuator
red, black, blue(old wire = green), brown(old wire = orange)
LNB
red black White
Right now I am watching:
Fox News comes in ch 18
Shop at Home ch 10
coming in from random south sat.
those channels come in w/ out any power wires, just coax cable.
SO HOW DO I hook up the wires to move the dish?
Two of the act wires will be bigger. They are the motor leads and go to the 4amp 24 v terms. If the dif isn't obvious you will have to look inside act.
The other two act wires go to pulse and ground. Not near the pol terms, but by the act/motor terms.
The two motor wires are interchangable as are the pulse and ground. However if you connect the pulse leads to the motor power leads at the rec, you will damage the reed switch in act.
i4tasWires said:
from accuator
LNB
red black White
these are the polarity wires to go to the servo on the Lnb... should be same color there...
the red and black should be the motor leads..(and will be larger) you can hook them up and maybe manually move the dish if your actuator control allows this... and maybe its not broke...
