Grounding the dish | SatelliteGuys.US
Grounding the dish
TimeHorse
38
The 75" StarChoice dish comes with a screw, washer and grounding clamp with a clip for a grounding wire. I do not see where these should be installed. Anyone know?
You mean the 75cm....a 75" dish is quite large:) I didn't ground mine due to the fact that the dish is fiberglass abd the ground screw does not ground the LNB.
Missing Some BEV Transponders in California
BEV Standard Operational Procedure
