Gtmedia v8 finder power switch starting to go | SatelliteGuys.US
Anyone else have a Gtmedia v8 finder where the power switch starting to go?
I've never used one of those meters but the power switch should not be a hard fix if it is the rocker type. Open the unit up and get the specs and size requirements. You should be able to find a suitable replacement at one of these parts suppliers. Then just unsolder the old one and solder the new one in it's place. ;)
