Guid Info problem-No Info Available | SatelliteGuys.US
lhfh
35
9
I am having a problem with my Guide Info. The problem is some of my Chicago locals show (No Info Available). Every thing else in my Guide has all the Info on what is on. Is any one else having this problem? I have run the update again with no luck. This has happened before.
:confused:
i had this problem last night on my 622 hd dvr but it was only on my hd channels i did a front panel reset and it didnt work then i did a check switch after going over the trouble shooting steps on the dish network tech site at tech.dishnetwork.com and it fixed the problem for me
Well I did a unplug, reset,check switch,and did a new update, no luck, so I shut it off. Came back an hour later and turned it on again and now it is OK.
I've been having the same problem for the last few days on about half of the Boston locals. I called dish tech support yesterday and the guy on the other end said that he had fielded four straight calls in a row on the same problem but that there was no known issue yet in the system.
This morning everything seemed to have been fixed but as of 7pm tonight, the problem has come back again. All of the major networks have data, but the remainder of the local channels show "no info available" after the current hour.
If anyone has any info on this that would be great; else I'm going to call back Dish on Monday.
I had similar problems with several Norfolk VA locals last night, even after rebooting.
What AMC - 14's loss means to Dish
HELP! Missing channels, Intermittent Signal and no Guide info
