Guide for which channels go with each satellite | SatelliteGuys.US
2x10
SatelliteGuys Guru
125
Pittsburgh, PA
I am looking for the guide that shows which channels go with satellite 119 and which channels go with 110
All local Pittsburgh channels used to be with 110, and I turned on my receiver last night and found no locals??????
Also, the channels I could get have me a message saying that my smart card did not authorize any of the channels??????
Can anyone help?
Thanks ---- Second issue
would doing a check switch for a super dish when I only have a Dish 300 to point a 508 screw up which channels are showing up on the guide?
If so, do I use the alternate dish while doing check switch?
There are only 2 options ----- Super and alternate.
thanks
Those checkboxes only affect what tests are run when you have Legacy equipment. If you have DishPro (SuperDish is DP) they have no effect.
Question on "Significantly viewed" locals
upgrade Questions
