Guys need some serious help....indoor ant | SatelliteGuys.US
John Davis sweatt
7
I bought an HDTV Phillips mant510 model and scanned channels gave me a few analog and 2 digital channels that are super wow!! Much better than my cable, problems is it's a vhf channel all the other channels really look like crap. The other locals are brodcast in uhf, I guess my ?? would be am I doing something wrong?? Also I checked antenna web and all of my locals are at the same degree that my digital channel (one good local) comes in on.
Thanks, John Davis sweatt
I wish a had some answers for you, but I had a problem with this same antenna where it worked better when unplugged! I can't figure it out. When it was turned off or unplugged I was able to get 8 out of my 12 OTA channels. When I turn it on i get absolutely nothing! I am going to stick with my bunny ears I guess. I would recommend a different antenna.
What's your zip, and which station(s) do you actually receive?
Does CM4221 get Upper VHF?
OTA Antenna Advice ?
