Hi Folks,
This is Eugene with another C-band BIG DISH issue.
The BUD II Project....
I do have a AJAX H-180 gear motor for a 10 foot mesh dish antenna.
However, I do NOT have the mount ring for the AJAX H-180 gear motor mount.
The only way to make one, is either IF anyone that has AJAX
H-180 ring mount who would be willing to draw a picture of
the ring mount for AJAX H-180.
Or I do have a spare ring mount, BUT it's for the Pro Form H-180 gear motor.
There's the difference between the 2 models. The AJAX H-180 mount is the OLDEST model, and the ProForm H-180 mount is newer after that.
So, I am thinking taking the ProForm H-180 ring mount to the local welder place, and have them copy it for using it with the AJAX H-180 gear motor.
It's a challenging. But I know what you're thinking.... Some of you might say,
"You gotta have the right ring mount for the right H-180 gear motor."
Although, as you know the H-180 ring mount is an A/ZE mount.
So, the only choice I have right now is to copy the Proform H-180 ring mount to use it with the AJAX H-180 gear motor with the 10 foot mesh dish antenna.
The extra 10 foot mesh dish antenna looks like KTI dish, but it's made by "Universal" brand name. That's OKAY, as long the mesh dish is the same.
Or IF anyone in the form who has or had a ring mount for AJAX H-180 gear motor, I would like to ask for a drawing of that ring mount for the welder to make one.
IF so, you could send me the attachment of the drawing.
The challenge thing for copying the ProForm H-180 ring mount for using with the AJAX H-180 gear motor, is that on the duplicate ring mount, the bar for the declination bolt, would have to be 1 3/4 inch higher. Because I predicted on how the AJAX H-180 gear motor would be in-place with the ProForm H-180 ring mount.
My 21 years old nephew believed what would be like if we
were to have it setup.
On the PDF attachment, you'll see the drawing that my nephew predicted.
But I think IF I can get the drawing of the AJAX H-180 ring mount from any of you.
Review my attachment of photos and the drawing, and see IF you can come up with on a ring mount for the AJAX H-180 gear motor.
NOTE, some places, like I went to on Tuesday May 13th, a welding place with my Proform H-180 ring mount. The two gentlemen looked and over view my Proform H-180 ring mount. They told me that they couldn't do it. Because the ring mount has thick steel, and that their machine doesn't bend, or cannot make a round shape. So, I came back home with my Proform H-180 ring mount.
When having the welder copy the ring mount, you also have to know that the copy of the ring mount have to be the exact same weight and ounces. Otherwise, your 10 foot mesh dish could collapse!!!!
So, anyone here has the drawing of the ring mount for the AJAX H-180 gear motor??? It would be kind of like a "BLUE PRINT" for the welder to make. But it's the challenging.
Hope my inquiry helps for answers.
Enclosed is PDF attachment of photos and drawing.
Download it and view it.
What do you think???
Thanks for stoping by to read my post.
