That's what I'm trying to do, but I can't get any OTA to come in. I am running with diplexors and if I plug the antenna cable into a set top digital tuner, it works fine, the H20 won't get OTA...very frustrating.
Diplexers won't work with the H-20, because the download frequency from the LNBs is the same as the OTA frequencies. You need to run two lines, one from your dish and the other from your OTA antenna, when using the H-20 and the AT9 dish. It will work with the older H10 and 3 LNB dish, but not the H20 and the AT9 dish.
