H10-250 and Lingo (VoIP) | SatelliteGuys.US
Ryu
22
grrr... So I get my new HD-DVR and it won't activate. It can't seem to make a solid connection.
I have tried a ,#034 and a ,#096 prefix with no luck.
Anyone run a 250 on a VoIP line?
I have my HR10-250 seutp with AT&T VOIP and have had no problems. I only had to tell the receiver not to detect a dial tone before dialing.
yeah, i tried that as well.
I'm going to try an external modem, anyone have any luck with that?
I had problems initially connecting to set up the DVR. I called a CSR and they had me type in all sorts of special codes. I do not remember what they were. They had me try 5 times to connect while I was on the phone with the tech. On the fifth time it connected.
With Lingo you must take it to someone elses house to do inital setup or us a null modem cable hooked to a PC from you Serial port on the back of the Tivo. Do a search on the TivoCommunity for a complete set of instructions on how to do it.
Yes, That works with Vonage and Callvantage. Weaknees sells it with the cable.
HR10-250 & OTA with Season Pass
Stupid question.
