H10-Skip Channels? | SatelliteGuys.US
H10-Skip Channels?
rlstjohn
22
Millersville, Maryland
Is there a way to configure the H10 to skip channels that I do not subscribe too? I looked and no dice unless I am overlooking something small. Thank you.
Robert
Robert
You can setup custom channel lists in the Favorites section of the menu. The H20 can automatically populate a channel list with all channels you receive, but you have to do this manually with the H10. After creating the custom channel list, set the current view to the one you created (Custom 1 or Custom 2). :)
Vertical lines on DTV ch 647
R15 Caller ID
