H10 with a VCR | SatelliteGuys.US
H10 with a VCR
fleetmack
60
Westminster, CO (North Denver)
yup - no tivo here
anyone know if it's possible to hook up a VCR to an H10? my roomy got one and is having trouble, i haven't looked at it yet but figured i'd post this before i get home to see if there's something tricky here.
You should be able to use "S"video and composite outputs to connect to the VCR. You will only be able to record SD.
fleetmack said:
yup - no tivo here
Yes, using S-Video or composite connections. But you can't control the VCR (turn it on and off) with the H-10 like you could with the HTL-HD or some of the other older receivers. You have to program the VCR & the H-10 separately. Seems like every time D* comes out with a new receiver, it has less features than the previous ones had.
Reception Problem
DirecTV Launches ‘RussianDirect’ Package
