H20-100 Software Release 0x407A | SatelliteGuys.US
levibluewa
1,150
7
WA, OR, CA
still has the same favorites glitch
Favorites - Channel - ID mis-match glitch
When setting up "favorites" you reach a point (channel #) where the box you're checking doesn't match the "channel logo" displayed on the right.
EX: box 544 TMC -- HBOHD logo is displayed
Anyone else noticed this glitch?
2nd H20-100:
box 544 TMC -- displays Directv logo
box 545 TMCw -- displays HBOHD logo
Note: Upgrade 0x407A (7-1-08)
H20-100: 0x407A
Staggered release began July 1, 2008.
  • MPEG4 video output stability improvement
  • UI polish for Signal Strength screens
  • Stability improvement for custom favorite list usage
  • Multi-switch compatibility improvements
  • XM channel stability improvement
  • Game Lounge stability improvement
  • Program guide data update behavior improvement
  • Favorite list and guide filtering behavior improvement
  • Minor remote control key repeat improvement
  • Slimline-3 ODU compatibility
  • New help UI screens
  • Native resolution behavior polish
  • Minor PPV UI polish
  • Added ATSC OSD for non-HD users
  • UI Polishing
  • Added Stability
  • Added HDCP behavior robustness
  • Guide filter not displaying channels from current favorites
  • Fixed Highlight disappears in Quick Menu
  • Fixed extra filter bar appearing in Channel banner info screen
  • Fixed highlight errors in call log screen
  • Improved Stability
Sorry for the delay, D* didn't send them until seven days past starting the stagered release.
A note about stagered releases: It can take a few days to a few weeks to releae these nation-wide. Generally they start on the west coast (zip codes) and work east.
How can you tell which version of the software (where do you look in the setup menu)?
Thanks!
Hr10-250
