I did a quick search and didn't find anything; is there a way to speed up the black screen in between changing channels; it averages about 5 seconds in between; thanks
You can turn Native off if you have it on. You can also switch from HDMI to component cabling.
I have component cabling; I will try to turn native off; thanks; if i can find it
my native is set to off already; is there anything else i can do?
Limited time offer
