H20 and OTA | SatelliteGuys.US
H20 and OTA
mac1
10
Ft. Lauderdale
Just signed up with D, they are installing AT9 antenna on 6/29, also getting H20. Is there a switch I can use that will allow me to combine my old Voom OTA antenna with the D feed so that I will not have to run additional lines?
Also, I was getting all Miami stations in HD on this voom antenna, now I am missing ABC, and FOX, which show up as VHF on antennaweb. Do I need to replace this antenna? If so, any suggestions? Thanks!
No, the AT9 will not be able to diplex OTA, you will need a seperate coax run for OTA.
Sorry, can't help you with this one, not enough data for a meaningful answer.
Mounting an AT9 on a vent pipe
Loss of signal
