H20 & H21 Software Release 0x4062 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,047
452
Central Michigan
The H20/H21 have a new release version 0x4062. Here are the improvement notes:
H20-100 released 4/2
H20-600 released 3/25
H21-100 released 3/24
Video Stability
System Stability
New OSD for viewing HD channels in non-HD resolution
HD output behavior improvement
Minor UI polishes for Signal Meter
Left arrow behavior polish
Interactive channel stability
"Under-the-hood" improvements
Significant HDCP Improvements
Modem behavior
Improved ATSC guide data reliabiity
Option to disable guide UI scrolling
How To Get Free Air Tv?
How Can I Get Some More Information On Getting Free-air Tv On My Direct Tv System. What Do I Need To Do The Switch? And How Much We It Cost Me? Can I Hook It Up Myself? Can You Get Caught From Direct Tv For Doing This Switch? Can You Use A Divo With This Freeair Tv?:)
Well that explains the recent sound problems, and 30 second skip lockups I have had on the HR20. I never had stability problems until this update.
Did this update apply to the HR units or just to the H20 & H21 units?
My HR20 has been pretty rock solid since I purchased it.
I have had audio dropouts ever since I got my 2 HR20s. Cant wait till this is fixed.
I have read that you can force a software fix for this.
I that corect?
Favorites - Channel - ID mis-match glitch
When setting up "favorites" you reach a point (channel #) where the box you're checking doesn't match the "channel logo" displayed on the right.
EX: box 544 TMC -- HBOHD logo is displayed
Anyone else noticed this glitch?
2nd H20-100:
box 544 TMC -- displays Directv logo
box 545 TMCw -- displays HBOHD logo
Note: Upgrade 0x4062 Tue. 3-25 234am
Coaxial Question rg-6 or rg-6Quad?
No sound on SD channels, HD channels work fine. H21 box
