H20 HD Receiver Software Release Notes 0x404A | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,047
452
Central Michigan
H20-100 - 0x404A & H20-600 - 0x404A
Staggered Rollout began 2/6/08 (Pacific coast -> East coast, could take days or weeks)
New feature(s)
White GUI
Improved
General stability improvements
SWM Performance improvements
Interactive stability improvements
Interactive behavior improvements
HD PPV stability improvements
ATSC stability improvements
Interactive to program guide behavior improvement
Remote control behavior improvements
Audio Behavior improvements on channel change
Channel Banner UI polish
System message improvement
Digital Audio output stability
System stability improvements
A/V stability improvements
Improved Search behavior
HDMI Stability
Remote behavior improvements
Interactive audio improvements
Minor UI Polishes
Minor UI Background polish
Minor System time UI polish
UI polish for Search
UI polish for To-Do list
UI polish for program guide
Minor UI polish for Signal Strength
Continued UI polishing
UI graphic stability improvements
No - these updates are just for H20, not HR20.
HR20 got an update a week or two ago.
Have you enabled RF mode in remote setup?
Ooops, no "R", how could I have missed that? The uselessness of the RF on the HR20-100 is well documented. I'm not sure if it's downloadable fix for it or if it's just an inferior manufacturing problem but when I saw those download upgrade, I had a dash of hope. That has since dashed away. :)
Cheers,
Robin
HELP - - Trying to setup HR21-700
Am I really imcompetent?
