H20 is almost perfect... | SatelliteGuys.US
Optical Serenity
330
Marietta,GA
The H20 is a great receiver, and would be perfect, but its SLOW...
The menu speed is almost unbearable, but otherwise its a great receiver. I love having the RF remote, and it has many options.
Ok, this is my rant of the week. But, to the meat of the post, are there any plans for a receiver that is faster? Like an H20 successor?
The H20-100 is much faster than the H20-600.
I doubt it's a hardware speed issue, more likely LG got the H20-600 to market fast instead of optimizing the firmware for speed.
I am hoping for a firmware update that will speed up the -600. Hopefully soon. It is a good receiver with the exception of slow guide/channel changes.
The H20-100 looks almost identical to the H20-600. What's inside is very different though.
The -100 runs cooler and doesn' crash on bad PSIP data from an OTA station.
The -100 guide is lightning fast. No comparison to the slow -600.
The -600 has a very slight edge in OTA (antenna) reception ability. If your local OTA signal strength is strong with no co-channel interference (or if you don't use an OTA antenna) this isn't an issue.
The -600 is made by LG
The -100 is made by RCA
Possibly rushed to market prematurely? I'm not so sure that it will get fixed. The -600s have had at least 2 firmware updates and they were aware of the sluggish guide at the time of these updates.
The -100 has had no updates. Only future one I've heard of is for the "active" feature.
LG's improving reputation will take a hit IF they don't get it fixed, they have been very reliable..... till now.
Jimbo
Jimbo
Maybe I am just lucky, but I have had few issues with my H20. It does run a little hot, but I have it sitting on four dice to help circulate air under it! The guide is a little slow, but not enough to get upset about. Also, the tuner is much better than any I have had.
raoul5788,
Which H-20 do you have ?
Just curious ....
Jimbo
Jimbos said:
raoul5788,
Just curious ....
Jimbo
The 600 by LG. BTW, it's Chip, Raoul is just a screen name. No offense, but your avatar drives me nuts!:D
Pretty much the same situation here.We have 2 of the H20-600s.They have performed well for us.They are both in open areas,so,they don't get hot.They are warm when I feel them from time to time,but,nothing major in that area.I reboot ours every now and then and that seems to help with the speed of the guide issue for awhile.I also agree with you on the OTA tuner,it is much better than what we had before we went to D*s service.
You can turn off annoying avatars in Thread Display Options.
If you dislike animated .gifs and you use Firefox browser, open a new tab and type
about:config in the address bar.
Look for the preference: image.animation_mode
Doubleclick that line.
Change the value to once and close the tab.
No more animations.
No more animations.
Thanks for the info. I do use Firefox.
Any idea where you can purchase the 100?
NESN HD Possibly on its way?
New to DTV
