H20 problem | SatelliteGuys.US
H20 problem
  • Thread starter Thread starter Hauser
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
Hauser
46
I have just noticed a problem with my H2. it was fine last night, and this afternoon, when I pushed the blue button to bring up the guide, the left end of it, where you can select the channel, was missing. Therefore the arrow up/over buttons didn't do anything at all. Anyway, then I cleared it and tried to change the channel using the channel up/down button, but nothing happened. I have to key in the chanel number in order to change the channel.
Was there some kind of update that caused this? I have done a hard reboot but the problem still exists.
Does anyone know the current version of the software being used on the H20?
My HR20 has no problems currently, just the H20.
Thanks in advance
HD Locals - Problems
H20 problem
