H20 Timer Problems | SatelliteGuys.US
H20 Timer Problems
mcbeevee
223
Have any of the H20 owners had problems with the program timer? The day on my "to do list" is different from the day on the actual timer screen. Version 0F03 was downloaded when I activated the receiver yesterday. Is this an old version of the H20 software? :confused:
This is a strange problem, since the Scheduler/Autotune function works fine if you leave the H20 on. If you setup a timer, then power off, it will not power on at the programmed time. The Scheduler History screen will show the timer was cancelled. One other person in the D* forum reported the same problem. The D* tech support guys said they have not heard of the problem and could only conclude that the receiver is bad. Maybe everyone is using Tivo/D* recorders instead of Scheduler/Autotune these days! :confused:
SBS (Korean channel)
Directway system
