h20 w/out service | SatelliteGuys.US
h20 w/out service
theslag
229
Hi all..
Im sure this has been answered before..but if i disco my H20, can i still use it as a OTA receiver??
Thanks!!
theslag said:
Hi all..
Thanks!!
As long as it has been previuosly been authorized you should not have any trouble.
Jimbo
No, once it has been disconnected, it will give you an error message (751, I think) when you try to use the OTA tuner. The H20 is the first D* HD receiver to do this.
Thanks for the correction, I presumed that all the receivers OTA worked once turned off, because all of mine have....
But I don't have a H-20....
So I presume this will be the case from here on out, I can see the reasoning, as from this point forward, everything will be leased and subject to being returned.
Jimbo
I think you right because that it will not let you use it OTA with a subscription...oh well.....
I know the older receivers were ok for this, but this is a new generation of receivers
Jimbo
Compass to find signal?
Local channels with DirecTV?
