Systems in this CE
H21-100 • H21-200
Window of opportunity to download:
Friday, December 19, 2008 11:00PM - 2:30AM ET
Saturday, December 20, 2008 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
New features
Improved/Updated
Known Problems
Notes
*** CAUTIONARY NOTE *** You've been warned
H21-100 • H21-200
New features
- 01 - Network
- 01 - Media Share
- 01 - Music Screen Saver
- 01 - Game Search
- 01 - 1080p/24
- 01 - OTA via the AM21
- 01 - Autotune
- 01 - Multi-Room Viewing
- View Playlist from a networked HR2x or R22
- Playback/Trick Play functions from any networked HR2x or R22
- Press {LIST} to see HR2x or R22 servers
- one playback per server at a time
- 02 - Parental Controls when scheduling autotune
- 02 - MRV: bookmarks and resume playback from previous location
- 04 - Friendly name in network setup
- 04 - QuickTune
- 05 - Built-in Self Test
Improved/Updated
- 02 - Support for more 1080p Sony TV models
- 02 - Faster Guide scrolling
- 02 - ATSC signal meter performance
- 02 - Fixed a screen saver issue
- 02 - ATSC setup screen now works on first boot
- 02 - Fixed reappearance of deleted autotunes
- 02 - UI updates
"tuner 2" and "tuner 3" references
- 02 - Fixed Gray Screen or a PPV OSD appearing overnight
- 02 - Improved "Try Again" when trying to connect to the Internet.
- 03 - AV1/AV2 remote code refinements
- 03 - Improvements to DHCP network setup
- 04 - Issues with rebooting while in standby
- 04 - WGA600N Support
- 04 - Static IP Setup
- 05 - Stability
- 05 - Missing "Just a few seconds" OSD
- 05 - MRV playback and trickplay problems
- 05 - User Interface polishing
Known Problems
- [strike]02 - Support for WGA600N[/strike]
- 02 - DHCP network setup
- 04 - Network Services may not work
- 05 - Diagnostic reports do not work
- 05 - H21-100, intermittent "Searching for Satellite" OSD
Notes
- 01 - Reverting back to National Release will go back to default settings
- 01 - To enable MRV:
- Network must be enabled
- Enable IAMANEDGECUTTER keyword
- Select Menu -> Parental, Fav's & Setup -> Miscellaneous Options -> Multi-Room DVR and choose On.
- Network must be enabled on HR2x and R22 DVRs
- 01 - Please test the box as a standard H21 before enabling the Multi-Room View Client feature and report issues
- 01 - Then please test MRV veggies before dessert
- 01 - When reporting MRV issues, please include the logs from both server and the client
- 01 - Please report all occurrences of "Unable to Access to Media" OSD with logs
- 02 - When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
- 01 - Do not have an unpurchased PPV in the server's playlist when displaying the playlist on the H21
- 01 - Do not have a currently downloading broadband program in the server's playlist when displaying the playlist on the H21
- 02 - The above Cautionary notes are less cautionary
