H21-25/HR20-24/R22 CE Release for the Weekend of 11.18 | SatelliteGuys.US
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
Systems in this CE H21 • H23 • H24 • H25 HR20 • HR21 • HR22 • HR23 • HR24 (all manufacturers) Note that this is now a unified thread for ALL HD receivers and DVRs except H20.
Window of opportunity to download: Friday, November 18, 2011 11:00PM - 2:30AM ET Saturday, November 19, 2011 11:00PM - 2:30 AM ET
Risk Level for this Download: Customer Candidate​
New features Quick format toggle for SD setups (press & hold EXIT) Improved/Updated
  • Parental Control
  • Wifi settings
  • Under the hood
Notes
  • This release features the new HD UI.
  • You may need to re-enter IAMANEDGECUTTER to send logs
  • This CE may remove your guide cache. Please allow up to 24 hrs to restore your full 14 day guide.
  • Your STB may restart during idle time within the first 24-48 hours of CE download
  • You will lose your guide cache when reverting from CE to national.
  • Please do not report sluggish issues or missing search results within the first 12 hours after download.
im guessing if it is a different one than the latest new hd gui I got it will be something along the lines of 0x0577 but thats just a guess, the latest hd gui I have so far is 0x0576 and there was 0x0575 before that one
I was half expecting to have it continue in the 057... area.
I guess the 04DB IS the current CE as it hasn't changed at all as it sometimes does as it loads.
This, I just finished a movie and tried my HR24 and it kept trying to get 04DB, rbr'd out of that and will wait a bit...
Don, thats what I'm getting also, are you sure thats not the NEW CE ?
I thought that version looked like an old one, but maybe not.
FWIW, this is the version that that Firmware site said was available, but I had heard that that site does NOT update for the CE's which made me think that this is not the CE software
Let it go ... is this your first try at getting ther new HD GUI ?
If so, thats typical, not everyones hung like that but many did.
This is my first try at getting HD GUI ... both my HR23's tell me searching, shows 04D4 and never starts downloading, just restarts and proceeds to receiver self check. Am I too early maybe ?
CE's for the Weekend of 11.18
