H21/H23 Audio/Video Sync Problems on Locals. Directv Aware | SatelliteGuys.US
civicbeater
62
In orbit
Not sure if others have experienced this issue. However, on H21's or H23's I have several properties across the country that will have issues on local channels with the audio/video not syncing up after an extended amount of time. The common denominator is that all properties receive locals off of 72.5 or 99/103. You can fix the error by rebooting the box however the issue will return, sometimes sooner than another. After contacting Directv, they state they are aware of the issue. This may not seem like a huge problem for most of you however these receivers are installed a feeding programming at commercial properties.
Anyone else?
Switch question...
MRV Gone?
