H21 & H23 CE Release 3/13 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE
H21-100 . H21-200
H23-600
Window of opportunity to download:
Friday, March 13, 2009 11:00PM - 2:30AM ET
Saturday, March 14, 2009 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
The Contents of this CE Download: (Differences based on last National Release)
  • Items from CE:17:01 High Risk
  • Items from CE:17:02 High Risk
  • Items from CE:17:03 High Risk
  • Items from CE:17:04
  • Items from CE:17:05 High Risk for H21-100 Moderate Risk for H21-200
  • Items from CE:17:06 High Risk for H21-100 Low Risk for H21-200
  • Items from CE:17:07 Moderate Risk for H21-200
  • Items from CE:17:08 Risk: Moderate (H21-100) Low (H21-200) High (H23-600)
  • Items from CE:17:09 Risk: Moderate (H21-100) Low (H21-200) High (H23-600)
  • Items from CE:17:10 Risk: Moderate (H21-100, H23-600) Low (H21-200)
  • Items from CE:17:11 Risk: Moderate (H21-100, H23-600) Low (H21-200)
  • Items from CE:17:12 Risk: Moderate (H21-100, H23-600) Low (H21-200)
  • Items from CE:17:13 Risk: Moderate (H23-600) Low (H21-100, H21-200)
  • Items from CE:17:14 Customer Candidate H21, Moderate Risk H23-600
New features
  • 01 - Network
  • 01 - Media Share
  • 01 - Music Screen Saver
  • 01 - Game Search
  • 01 - 1080p/24
  • 01 - OTA via the AM21
  • 01 - Autotune
  • 01 - Multi-Room Viewing
    • [*]View Playlist from a networked HR2x or R22
      [*]Playback/Trick Play functions from any networked HR2x or R22
      [*]Press {LIST} to see HR2x or R22 servers
      [*]one playback per server at a time
  • 02 - Parental Controls when scheduling autotune
  • 02 - MRV: bookmarks and resume playback from previous location
  • 04 - Friendly name in network setup
  • 04 - QuickTune
  • 05 - Built-in Self Test
  • 13 - Advance setup in remote control
Improved/Updated
  • 02 - Support for more 1080p Sony TV models
  • 02 - Faster Guide scrolling
  • 02 - ATSC signal meter performance
  • 02 - Fixed a screen saver issue
  • 02 - ATSC setup screen now works on first boot
  • 02 - Fixed reappearance of deleted autotunes
  • 02 - UI updates ("tuner 2" and "tuner 3" references)
  • 02 - Fixed Gray Screen or a PPV OSD appearing overnight
  • 02 - Improved "Try Again" when trying to connect to the Internet.
  • 03 - AV1/AV2 remote code refinements
  • 03 - Improvements to DHCP network setup
  • 04 - Issues with rebooting while in standby
  • 04 - WGA600N Support
  • 04 - Static IP Setup
  • 05 - Stability
  • 05 - Missing "Just a few seconds" OSD
  • 05 - MRV playback and trickplay problems
  • 05 - User Interface polishing
  • 06 - Network services, Network setup, Network status
  • 06 - One touch autotune via Enter key
  • 06 - H21-100, SWM compatibility--will not affect other boxes
  • 06 - H21-100, remote control support
  • 06 - Removed "Reformatting Hard Drive" screen after Reset Everything
  • 06 - Changing Display Language
  • 07 - One touch autotune via Enter key
  • 07 - WGA600N setup with WPA encryption
  • 07 - Receiver not resetting
  • 07 - Closed Captioning Loss
  • 08 - Autotune on ATSC channels
  • 08 - WGA600N setup with WPA encryption
  • 08 - UI Improvements
  • 08 - Missing spending limit unlock OSD
  • 08 - SWM issue, Signal Strength H21-100
  • 08 - System test H21-100
  • 09 - Network Setup
  • 09 - Autotune on ATSC channels
  • 09 - Keyword search
  • 09 - Screen flash coming out of Standby
  • 10 - Improved Front Panel display on boot up
  • 10 - IR Remote H21-100
  • 10 - Remote setting when reset defaults
  • 11 - PPV spending limit conversion (compared to national release)
  • 11 - Video when switching to alternate audio
  • 11 - Fixed blank reset everything screen
  • 12 - Stability fixes
  • 12 - Faster keyword search
  • 12 - Reset everything warning message
  • 13 - Autotuning when using parental controls
  • 13 - Fixed "tune to 201" issue
  • 13 - Reset defaults correctly sets the hide/show SD duplicates option
  • 13 - Updated connection successful message in Network setup
  • 13 - Stability
    [*]14 - Autotune Fixes:
    • Manual with past start times
    • Lingering icon after canceling
    • Parental Controls
    • Minor polishing
    [*]14 - Updated welcome screen and help messages
Known Problems
  • [strike]02/06 - Support for WGA600N[/strike]
  • [strike]02 - DHCP network setup[/strike]
  • [strike]04 - Network Services may not work[/strike]
  • [strike]05 - Diagnostic reports do not work[/strike]
  • [strike]05 - H21-100, intermittent "Searching for Satellite" OSD[/strike]
  • [strike]06 - H21-100, signal strength screen[/strike]
  • [strike]06 - H21-100, may lose satellite signal after several hours requiring reset[/strike]
  • [strike]07 - WGA600N setup with WEP encryption[/strike]
  • [strike]08 - WGA600N setup with WEP encryption[/strike]
  • 09 - WGA600N setup with WEP encryption
Notes
  • Reverting back to National Release will go back to default settings
  • 01 - To enable MRV:
    • [*]Network must be enabled
      [*]Enable IAMANEDGECUTTER keyword
      [*]Select Menu -> Parental, Fav's & Setup -> Miscellaneous Options -> Multi-Room DVR and choose On.
      [*]Network must be enabled on HR2x and R22 DVRs
  • [strike]Please test the box as a standard H21 before enabling the Multi-Room View Client feature and report issues[/strike]
  • [strike]Then please test MRV (veggies before dessert)[/strike]
  • [strike]When reporting MRV issues, please include the logs from both server and the client[/strike]
  • 01 - Please report all occurrences of "Unable to Access to Media" OSD with logs
  • When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
  • If you are losing favorite channels after download, please wait about 30 minutes after the download and check again. If favorites are still incorrect after waiting, then please report the problem.
  • Please report non-MRV issues only
Be sure to double check your full model number before forcing a download
So far only thing I've noticed is the AM21 still remains powered on when powering down the receiver.:( So far I haven't lost video when changing channels.:)
Thanks,
LGM
Spoke too soon.:( Lost video when switching channels twice last night. No other receivers in the house have the problem. There's no error message, just randomly when changing channels, the screen goes to a "gray" screen.
At that point no other channels will come in, menu and search screens work fine. Only way to clear it up is to restart. :mad: I've moved the receiver to other places in the house, same issue. It is the only h23-600 in the house, the rest are 11 series, and an hr23 series.
Not sure if it's a bad receiver, but I don't recall having the problem before I started applying the CE updates. I guess my next move is to re apply the "national" release and see if it continues to happen.:confused:
Thanks for listening,
L.G.M.
H23-600
I had the same thing happen with one of my H23-600's. It just freezes up on the searching for satellite and won't let me do anything until I restart. It has happened once since Friday night. It still is more stable than the national release though.
The strange thing with mine is there's nothing - no error message at all. The screen just goes gray. Totally blank. No searching messages or anything else. I know it's not frozen because the guide and menu buttons still operate.
Changing channels to one on a different sat doesn't have any affect. I had a case a few releases ago that resulted in 721 errors at random times. This is similar, but no error messages of any kind.
I hate to go back to the national release, because I'm using an AM21 for OTA locals. I will just for testing to rule out a faulty box.
Thanks,
L.G.M.
D11/D12 CE Release 3/13
CE's for 3/13 & 3/14
