H24 and phase 3 dish | SatelliteGuys.US
odisbach
3
kentucky
Can a phase 3 dish be used with a H24-100. I have signal on 101 and 119 using a birdog meter, but H24 does not find. The setup does not lst phase 3 dish as option, only slimline 3 SWM.
It should work, but you need to have the correct dish selected in setup. The only dish option is a slimline 3 swm?
I will check setup again tonight, the only other option for a dish was grayed out . Am going to try a single LNB dish tonight for just 101. This is a H24-100.
Thank you
Got it working. Once I hit select and chose the phase 3 dish and change to multswitch everything load up great. I did not understand how the menus worked thanks a lot.
Thank you all
what dish needed
How Many?
