Hi all, Just activated my H24 (owned) tonight and it wont stay on any channel for long.
Front DTV light starts blinking by itself then channels change, goes to menu, back to guide, etc. Remote is set to IR, THX for possible solutions! Bill
Hi all, Just activated my H24 (owned) tonight and it wont stay on any channel for long.Front DTV light starts blinking by itself then channels change, goes to menu, back to guide, etc. Remote is set to IR, THX for possible solutions! Bill
Any other remotes in the area (other rooms or even a nearby window), may try moving the receiver slightly or using an RF remote.
Is it hooked up to the internet? Is there anyone in the house with an ipad?
If not try doing a hard reset.
What's your setup like? SWM? Did you install this yourself?
I once had this problem with a H20.
Was someone sitting on the remote ?![]()
...Looks like what mine is doing. What now has me puzzled is why does it work in living room but not in my bedroom? I looked at the cables and my living room has RG-6 coming out of wall into HR45 but my bedroom has some king of cable tv cable with 57 on it, not RG-6. Also length to room is pretty far. Could the lack of RG-6 out of wall into receiver maybe cause issues like this? THX! Bill
It's almost certainly interference with the front touch panel. I have an HR24 that behaved the same way. I moved it, and reran all the cables that went anywhere near it, and that solved the problem. Another poster said their H24 was on top of another piece of electronics that used a touch panel - moved the H24 and the problem went away.
DTV said issue would need to be elevated up to enginnering level. Think I will return H24and start over. THX all again for all your help/suggestions! Bill
If your gonna return it, see if they will get you another HR24 instead, seeing you already pay the drv fee, there really no reason to not have ALL DVR's.
Limited time offer
