H24 with OLD Dish | SatelliteGuys.US
H24 with OLD Dish
davidmustang
23
2
SC
I may use a old dish with the H24 for camping this weekend. If I do, will I need to use the PI and B band converter? I understand that I will only get SD picture.
No . ...
No PI, as the old 101W round dish only uses 13v/18v legacy switching signals from the receiver . ....
And no BBC needed either, as those are only used for receiving Ka B-band HD (and some SD) signals from the 99 and 103W satellites by equipment operating in legacy mode.
Sent from my LM-V600 using Tapatalk
Thank you for the information. Do you know what set up I need under the satellite. I know I use 18 inch round receiver, but what switch setting?
Use the "SL-3" dish setting ...
And perhaps set your guide preferences for "Hide HD channels" ....
Switch setting should be on "Multiswitch". ...
