H25/100 DVR list empty after update. | SatelliteGuys.US
wolfievtec
34
4
Ever since all my boxes updated to the new firmware my H25/100 box always has a blank DVR list unless I reset the box daily. My genie is 0xffc and my H25/100 is 0xb87. Anyone else having that issue? Any ideas?
How long did you go after the update before you reset the box ?
Often times Recordings will come back with in 48 hours (if you lose them) not always, but i would try it next time.
on the H25 - Menu restart the receiver or press the red button -does anything change? did it come if not check to see if the internet is connected - Without it (connected you won't pull a List from Whole home ) Sub net 169.
I am having this same exact problem and each time it happens the only way to get the list back is to restart the receiver which is annoying since I only use this box when I am going to bed at night in my bedroom. Has anyone figured out a fix for this?
This problem still happens for me, I never found a solution unfortunately.... let me know if you ever find a solution. Thanks!
New HR54-700 On demand & ESPN app
Question re Legacy LNB with H24 receiver
