H25-500 install | SatelliteGuys.US
H25-500 install
cerjam
3
washington
so heres my situtation. i have a H25 reciever, and I need to install the dish that goes with it. from my reading, it requires a SWiM setup, and i've only worked with old old SD single lnb dishes so my question is this.
what am i going to require to make this actually work. i have the reciever, and i figure i need a 5lnb slimline deal with the onboard swm deal. what else?
thanksguys!
You will need the Slimline dish, a swm lnb that is either 3 or 5 lnb depending on where your local sd channels are, and a power inserter. If you are doing this by yourself, Solid Signal is a good source of these parts.
If you are smart you will call D* and order the installation, it might even be free depending on your circumstances.
Not a particularly friendly way to start a reply, is it? ;) If you checked his other posts, you might understand why he is doing it himself.
Switching from Cable
Suspending Service question
