H3 request: Longer post-show recordings | SatelliteGuys.US
With 4 tuners I understood the need to cut off the max at 90 minutes.
I doubt that the # of tuners was a determining factor in a 90-minute "limit". They base the extension time on what is pretty normal. Can they add more options ? Sure they can, but where do they draw the line ?
Considering our luck lately with Dish and user-configurable options, we should probably just be happy that they didn't take any of the extension options away yet.
You can always set a timer for multiple shows that are scheduled for after the event too.
Sent from my HTC One M9 using Tapatalk
I'd draw the line at maybe somewhere around 3 hours?
Good idea! Can you walk me through how I would set up a timer to automatically record all Yankees games and then the 3 hours worth of shows after it?
Reactions: DWS44
Updates?
Can the Super Bowl be archived to an EHD?
