H360 on H3 has arrived | SatelliteGuys.US
BatStang2000
38
50
Received H360 on my Hopper3. Date and time show 08/07/2023 @ 4:57PM. When I turned on the H3 this morning it said total signal loss, so I immediately checked to see if a new version had come in. About a minute later, the channel appeared for about 20 seconds and then disappeared again. This cycled through 3-4 times at which I did a Tools> Reset. Same thing after it completed. I then did Status> Check Status, it found low signal on port 2. (Background info - I just had a new dish and lnbs installed recently, so I knew it was good) Then I did Dish> Test Installation. When it finished, everything appears to be working now.
Still on H353 on Hopper3 here.
Reactions: charlesrshell
This afternoon both of my Hopper3 receivers updated on their own from H358 to H360 and my Joey3 updated to J560. I have not noticed any problems with this update. Trick play is working on recordings on my local Hopper3 and from my remote Hopper3. I will continue my testing.
hopper 3 plus
Does the Dish Everything package include local channels?
