Had an idea tonight... | SatelliteGuys.US
Shawn95GT
Tivo fanatic
2,278
Phoenix, AZ
I've had this nice Channelmaster feedhorn for the Primestar dish laying around and I never put it to use since I don't have a C120 flange LNB.
What I did have is a WR-75 flanged 0.8 Ku LNB that came on the dish when I got it as well as a waveguide that separated the H & V signals.
Today the Norsat 8115 C-band LNB came in so I swapped it and the new 4106a LNB onto the CalAmp C/Ku feedhorn which will be going on my 5' mesh. What I ended up with is an extra 0.7 rated WR-75 flanged Ku LNB (CalAmp) that came with the C/Ku feedhorn.
:D
Now I have a Horz and a Vert LNB.
Add one 3x4 multi-switch left over from my Voom install and now I've got a ghetto quad linear LNB that'll work with the CM feedhorn! :clap
I think you will find that those .6db LNBs will rival most of the .3/.4db LNBFs out there due to the better rejection from the feedhorn, and overall better quality of the lnb..
Guess I don't understand what this is for. Is it C-band only or is Ku in there somewhere?
It's all Ku :cool:
That's seperate H and V LNBs that mate to a C120 flanged Channel Master feedhorn via a waveguide. The CM feedhorn is optimized for the oval dish. A C120 flanged Invacom may work better when paired with this feedhorn but I had all this stuff laying around so I'm going to put it to good use :).
Because of the feedhorn alone I expect it to out-perform my 40mm necked Univeral LNB on the same dish.
The LNBf on the wing is a normal DSS one.
It's on this dish:
Shawn
How To .......?
36" Fortec Elevation Help
