I have the 700 DVR. Have had it prior to when the HD satellite went up, so I couldn't verify that I was getting everything I should get. Well, I can't see 1/2 of the HD channels. I get the searching for satellite message when I switch to them. (I hadn't been able to deal with this much over the last 6 months and I'm finally able to do something about it).
I had DTV send a tech out. He was lost. After 4 hours, I got tired of him being there and sent him away. 5 minutes later, I was able to determine that it is likely to be one of the RG6 cables going to the receiver. (The tech did swap receivers and switches with no effect)
As I swap the two sat connections, the HD channels that don't come in, reverse. (i.e. the ones that used to come in, don't. And the ones the didn't come in, do).
The cable I suspect is the only one that's run outside the house. It's a much longer run than the other input, which is fed in through the house. It's probably close to twice the length. Would this be causing the problem?
I don't have this problem with any non-HD channels.
This is really odd to me and also very annoying as i want my HD!!!
