Harmony 880 and 921 | SatelliteGuys.US
Harmony 880 and 921
Squiglee
24
2
Has anyone configured a Harmony 880 with the 921? How did it go?
I have a MX 500 fully programmed that controls the 921 (all functions programmed in and working nicely) and all my other stuff but I really like the idea of how the Harmony works. Any my girlfriend who is not as patient when the devices get "out of sync" with the remote would appreciate a simpler solution.
Compare MX500 and Harmony
Thanks for the note. Has anyone used both remotes? Can you compare the two?
At my house, the MX500 and MX700 have been put away. The Harmony 676 and 880 are much preferred, here.
harmony 676
I don't konw about the mx, but from my experience I can tell you that the Harmony 676 was easy to set-up with my 921, marantz dvd player, jvc vcr, and mitsubishi rptv. The few set-up issues I had were solved by the best tech support team I've ever dealt with in Toronto (this team is everything DISH support isn't!!!).
The Harmony even recognizes a Radio Shack A/B switch!
Cheapest deal for 942 as a new sub?
Installing Dish - installer rules make it impossible!
