I was looking for a fta receiver and came across the MANHATTAN DJ-1997.
Has anyone use this receiver for fta?
And used IPTV on this receiver to get internet radio?
Quick question Christopher,I'm hoping to get into C-Band this year!!! How does your 1.2M dish work on C Band?? Also which sats are you on?? How's the Q? Thanks. Regards Toronto Canada
If you want the best of C band go with a 10 foot dish. If you want to have something to play around or don't have the ability to have a 10 footer then mini budding is best. Chris what channels do you get on 107w or 111w?
You get the same results that I do with 107w and 111w. Whats your results on 103w? We have similar problems with the weather when it gets cold. When its cold its easier to receive multiple satellites at the same time. Then you lose some transponders did you lose pr vi mux?
Can you make up a list go by each satellite when you have time so we can compare what we can recieve? Same results on KRBK haven't had them since last year. I 'll check out that channel when I get time Chris, the tire channel. I can only go from 87w c band to the west. Keep up the good work.
Limited time offer
