Has the power increased on G10? | SatelliteGuys.US
iafirebuff
4,394
8
Waterloo, Iowa
I turned on the Fortec for the first time since Sunday when I shortened the cables that are feeding it (I only turned it on to see if it worked, did not look at the #'s). Anyway, I used to get 33-40% most of the time and 40-46% fluctuating on good days on 11720. Well tonight I am getting 53-60% on 11720, mostly staying on 60%! There are 2 things different since I used this last: 1) I shortened the cables out at my utility box where the switch is located (shortened by about 3') and 2) the Dish 500 was mounted below and to the side of the 80cm dish. Could any of those have anything to do with my new found signal strength, or is it something Equity has done? THANKS!!!!!!!!!
shhhhhhhhh....don't jinx it :)
I asked the same thing in my "do you have a separate dish for G10" thread :)
I got hooked by reading this WEB Site by accident
Discovered why my Primestar has bad rain fade!
