Hauppauge introduces the HD PVR 2 video recorder | SatelliteGuys.US
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
Whats the difference in that one and the "Gaming" one that is $40 less?
"The HD PVR 2 records in the AVCHD format, which is the format used to master Blu-ray discs."
I'd like to know how well this would work with Dish recordings. I've got a few on EHD that I'd feel better about if I could put on Blu-ray.
As long as they don't have HDCP they will record pretty good, I was happy with the 1212, but its not being recognized by my pc's. The gamer only gets 2 channel sound via HDMI (no optical port) but will record some higher bit rate and cleaner looking recordings than the 1212 did.
Google CFO Says They're Working on 10 Gbps Connectivity
Help choosing DLP Lens cleaning cloth
