Have 110, 129, no 119 | SatelliteGuys.US
brhntr4
2
Nebraska
I have a Vip211k with a 1000.2 western arc dish.
I can get both 110 and 129 signal strengths into the 60's at the same time but cant get anything on 119.
I've moved the dish all over the place and still can't receive any signal on 119.
Ideas?
Zip code is 56278
If he's getting 110 and 129, the skew is correct. It's almost gotta be the LNB. Could try to move coax connections to see if the problem "travels" - but I really don't think that's the case.
I think what they were saying is that if you had the skew wrong you could essentially hit both wing satellites but have the wrong elevation for the 119. Not very likely, but possible. Are the 110/129 getting good signal strength, or just enough to show up?
Well, I suppose you're right, if he has low signal quality on the others. This will be interesting to follow.
HMDI not working
Some channels not showing on favorites list
