Have a copy of a manual or factory software for a FTA reciever? | SatelliteGuys.US
Mr Tony
3,399
14,910
Mankato, MN
Do you have an electronic copy (PDF, Word document, etc) of an old C-Band receiver or FTA receiver that someone might need?
Do you have a copy of LEGAL software for older receivers that someone might need?
Do you have an electronic copy of anything FTA related that someone else here might benefit from?
Do you want to help out your fellow Satelliteguys FTA members?
If so....then WE WANT YOU!!
We have updated the ability for members to submit files directly via the NEW downloads section. You will see it at the top of the page.
To submit a factory software file or manual
-click on the "downloads" option (top of the page)
-select which topic (manual or firmware you have)
-click on "add new file"
-under file name give it a name (if you are confused on how to name it see how I have been doing it)...you dont need to put anything else in
-scroll to where it says "upload a file"
-select your file form computer (either zip or pdf will work)
-click "add file" and it will upload it
Note that all files will be checked by staff to verify its a legal file. No I wont be loading these but if I have any questions, I'll PM the member who submitted it.
Some file names may be edited by staff for continuity
Pretty much anything is accepted :)
just letting folks know if you upload something please PM me letting me know. The files sit until staff approves them
Thanks!
What satellite is where?
found the monster
