Have a problem recording with DVR | SatelliteGuys.US
sullic82
90
I am trying to record Big Brother 8 and when I do it says I cant have more than 3 recordings at once. But when I went to my future recordings, their wasnt any. What do I do?
2 ideas might help
Check to see if you have something recorded that goes past the hour -- like to 10:01. If you do and you have 2 shows set to record at 10:00 there is your third recording.
If that is not the problem then. I would do a full reboot. Turn off the box and the TV. Unplug the box for about a minute and then plug it back in. It will take several minutes to reboot, it is done when the time comes back up. The you should be good to go.
I do this to my box 8300HD about every week or two and seem to have very few problems.
cnet-tv on CV
Voom HD is Coming June 26th through 28th
