Have Dish 1000, need 61.5 | SatelliteGuys.US
mikenewy
SatelliteGuys Guru
129
I live in zip 28422, have Dish 1000 and would like to receive DC HD locals on 61.5.
Currently D1000, gets 119/110/129, I have DPP44, so their is room for another sat. input. What is the easy way to add 61.5? Can it be reaimed to take the place of 129, or do I need another dish. I do have an old DTV legacy dish in the closet. Thanks for the help.
You can not reaim your Dish1000 to hit 61.5.
You would need a DishPro LNB to use on the dish in the closet. The tube will be different that the Dish LNB but you can make it work. That is what I have used for 3 years. Then just run a line to your DPP44 switch.
Great service from tech csr
pixelation
