Having ASC1 Issues | SatelliteGuys.US
Having ASC1 Issues
JFOK
1,105
839
Cape Cod - MA.
Hi All,
In an attempt to clean up the satellite wiring in my "man cave" and make it more presentable, I ran into a problem with my ASC1 mover.
I trimmed my coax cables to get rid of unnecessary slack and did the same with my dish moving wires. Now...I took a picture of the wiring prior to disconnecting, to prevent any issues. After reconnecting I find that my dish moves a click either way and then stops. I get the error message
Reached w/e limit, limit switch? sensor?, motor blocked? press ok to return. I rechecked my wiring and all looked good, so I figured after a few more tries, I'd do a system reset which is something I didn't want to do since I had all the satellite position numbers memorized. So I did the system reset by selecting system reset from the menu and then pressing OK. Next I pressed the down arrow to select soft limit reset and then pressed OK twice to confirm software limit deletion.
However, after all that, instead of seeing 0000 for east and west positions. I see -5000 for east and +5000 for west. When I go to move the dish it moves 1 or 2 clicks and it stops and I get the error message again.
All was working fine before I got ambitious to tackle this "cleanup."
Any ideas ??
John
Yes, pictures can help. It for sure is not detecting pulses from the actuator.
Reactions: JFOK
Either the motor is not moving or the reed switch count is not being received. I wouldnt reset the ASC1 as this problem has nothing to do with the default -5000 / +5000 software limits. You dont want to see 0000 for East or West Software limits. If you see 0000 for both East and West software limit settings, the motor would never move.
Likely a wire wasn't reconnected properly.
1. With the error message cleared, tap the East button for less than 1/2 second. Does the motor momentarily energize and bump (slightly move) East? Does the position count change?
2. With the error message cleared, tap the West button for less than 1/2 second. Does the motor momentarily energize and bump (slightly move) West? Does the position count change?
If the motor momentarily energizes and steps East or West, the M1 and M2 wires are good.
If the motor momentarily energizes and steps East or West and the position count changes, the M1 and M2 wires are good and the S1 and S2 wires are good.
3. If the motor doesn't momentarily energize and and will not step East or West, the M1 and M2 wires are possibly not good.With the error message cleared, check the DC voltage for momentary 28-36 volts when the East or West button is depressed.
Reactions: JFOK
Hi Magic and Mike,
Thanks for responding to my message.
I will try later this evening to send out a picture if I continue to have no luck.
John
Brian,
Thanks for responding.
I'm thinking I probably screwed up the wiring also.
The motor engages and position count does change slightly when bumped east or west...0000 to 0003 each way.
John
Magic, Mike and Brian,
Problem solved. :clapping
The M1 wire was loose in back of the ASC1.
All is operating well once again except i have to re-number my satellites since I did a system reset yesterday clearing the system of my numbered satellite locations. Now I can finish the man cave cleanup.
Thanks again for your responses.
John
