None of our three Rokus will play any program. Firestick will, but EXTREMELY slow to load. AppleTV is Fine. Tried all the normal fixes to no avail.
How old are the Rokus?None of our three Rokus will play any program. Firestick will, but EXTREMELY slow to load. AppleTV is Fine. Tried all the normal fixes to no avail.
That's a good possibility.The Batman is in debut and I believe that there are server overloads going on. Give it a day or 2 to fix itself.
Did all that. I think Batman is the problem.Delete the HBO MAX app and then readd it and sign back in and it should work again. When you add it back in it will grab the latest software for the app and you should be good. I also would restart the Roku.
Did you get a software upgrade for that Roku recently?None of our three Rokus will play any program. Firestick will, but EXTREMELY slow to load. AppleTV is Fine. Tried all the normal fixes to no avail.
Nope, not since December, and it says it is up to date.Did you get a software upgrade for that Roku recently?
I have had that happen with netflix..and it was a netflix issue..have you emailed HBO?Nope, not since December, and it says it is up to date.
So glad I bought an AppleTV.
Don't care. Have other options,I have had that happen with netflix..and it was a netflix issue..have you emailed HBO?
Limited time offer
