HD-15 or RGBHV output | SatelliteGuys.US
caryt
11
Thats what I need from Voom. I would like to get Voom's DVR when it come's out but why if I can't hook it up :no . I have a 9" FP in a dedicated theater room and need either a HD15 or RGBHV outputs. Am I sol :mad: Also will Voom ever carry :rolleyes: network HD feeds? The OTA tuner won't help as I can't get any OTA, I am in the boonies :D
Thanks, Cary
Thanks, Cary
I think there is a very good chance you'll see the HD National Feeds of ABC, CBS, FOX and NBC in the coming months...should VOOM survive of course.
Thanks, Cary
Welcome to the forum. You will need a RGBHV to Component converter to connect your stb.
ReplayTv Codes For Use With VOOM Receivers
Letterbox HD content on 4:3 SD set
