HD and TFC | SatelliteGuys.US
HD and TFC
worker
11
I have recently added an HD DVR and HD receiver. I'm not getting all of the HD channels because I have a 3 LNB dish (Channel Master) and the dish for TFC, all connected though the Zinwell WB68. It looks like I need to replace the 3 LNB dish with an AU9-S. Is that correct? Will this allow me to receive the missing HD channels along with keeping TFC? Does the Ka connect to the unused flexport on the WB68?
Yes, this switch is suitable for your intended use & providing you already have two coaxial cables 'runs' to your DVR locations you might as well keep it with your new slimline (AU9). Some installers are already using SWM Slimlines dishes so you might want to request the older 5lnb Slimline in your case. The flex port should still be able to feed the international bird.
2 Antenna's
Ebay Model HR20
